Top 5 Best 4K UHD Blu-ray Players (Hardware)
2019-03-19 04:17:24     Posted by Gabriel
7923
Summary: In this article we will list some of the best 4K UHD Blu-ray players with and without HDR10 support and keeping your budget in consideration.
Since a long time now, Blu-rays have been recognized for high definition entertainment. With large storage space it became possible to store high definition content on a Blu-ray disc. You can find multiple Blu-ray disc configurations like BD25, BD50, and BD100. BD25 and BD50 can be considered the normal Blu-rays, but BD100 is what which is known to deliver the 4K UHD entertainment on a 4K screen. The UHD entertainment became possible with a large storage size of the BD100 disc which is nearly 100GB. So a larger storage means ultra high definition entertainment. But BD100 is not something like BD25/50 which can be played on common Blu-ray players.
To play a BD100 one should be having a 4K UHD Blu-ray player. And also note one thing that 4K UHD players also support HDR10 which is a technology which enhances the 4K UHD quality. It is a camera feature that shoots the movies and the quality gets digitally encoded. Some 4K UHD players recognize it and some not. Basically this will create an image quality difference. So, in this article we are listing some of the best 4K UHD Blu-ray players with and without HDR10 support and keeping your budget in consideration.Click Top 5 UHD Blu-ray Player Software to check the software player.
Part 1: Top 5 Best UHD Blu-ray Players
Here is the list of top 5 best UHD Blu-ray players from different manufacturers. Instead of going in details of every Blu-ray player listed here we will just highlight the main features with price.
1. Panasonic DMP-UB700
Priced at around $600 dollars the Panasonic DMP-UB700 is a nice 4K UHD Blu-ray player with sensational image quality. It also delivers excellent normal Blu-ray performance. Just like the high definition video it also supports high res audio. And also has Amazon and Netflix onboard.  It can also play normal Blu-rays, 3D Blu-rays, DVDs and CDs. If you are a Netflix lover then you can watch it in 4K-HDR.
2.  Xbox One X
Xbox One X is the latest video game console from Microsoft. It claims to be 40% faster than any other gaming console in the world. Though its a gaming console but people still prefer it because of its true 4K UHD experience. Xbox One X is euipped with a 4K UHD Blu-ray disc player with HDR10 support. So, now we don’t need to explain much just remember that true 4K UHD means Xbox One X. Its price is around $600 which is nearly double than a normal 4K UHD player. But do remember it’s a gaming console with true 4K UHDso a higher price tag won’t bother most people.
3. Panasonic DMP-UB300
The Panasonic DMP-UB300 is prices at around $350 and is known to give First class 4K UHD Blu-ray picture performance. You can watch YouTube, Amazon and Netflix movies though this 4K UHD player. It delivers top-notch video quality with the HDR10 support.
4. Sony UBP-X800
Looking to play almost any video format? Then go for Sony UBP-X800 Sony 4K Blu-ray player. It is a 4K UHD Blu-ray player which only costs $299 giving out the best value for your money. It also supports dual HDMI for separate audio and video output. It has built in Wi-Fi and Bluetooth and supports live streaming and screen mirroring. It has got nice connectivity options for all your high-tech audio video components. At just $299 it is the best 4K UHD player.
5. Samsung UBD-K8500
Priced at only $299 the Samsung UBD-K8500 is one of the best 4K UHD Blu-ray players. The price is similar to the Sony UBP-X800 but Samsung UBD-K8500 doesn’t provide Wi-Fi. It has a LAN port instead for connecting to your home network. It’s a nice Samsung 4K Blu-ray player.
Part 2: DVDFab UHD Copy: Best UHD Solution to Copy UHD Blu-rays.
DVDFab UHD Copy is a 4K UHD Blu-ray copy software which is specially designed for 4K UHD discs, ISOs, and folders. With the help of DVDFab UHD Copy you can copy an entire or just the main movie on a 4K UHD BD disc to an ISO or a folder in 1:1 lossless ratio. Not all the time you can buy those expensive BD100 blank Blu-ray discs. So DVDFab UHD Copy can compress and convert the BD100 media to fit on a BD25/50 disc or ISO. During the compression and conversion process, the BD-XL’s 2160p resolution is retained and gets copied to the new blank BD-50/25 disc, ISO, or a Blu-ray folder but with a reduced video quality.
You can also use the clone mode to clone your entire 4K UHD Blu-ray disc to an ISO file. If you don’t have a BD-100 disc but an ISO or a folder then it will be treated the same way as if it is a physical disc. You can just compress that BD-XL ISO or folder to a BD-50/25 disc, ISO, or a folder.
So what you should remember in layman’s terms is that if you need a 4K UHD copy software then you should go for DVDFab UHD Copy. Just remember its main functions as listed below.
·         It works with 4K UHD Blu-ray discs, ISO, and folders.
·         It can compress 4K UHD BD100 (BDXL) media to fit on a BD25/50 discs. Can also be saved as BD25/50 ISO or folder.
·         Clone mode lets you clone the entire 4K UHD Blu-ray disc and save it as an ISO.
·         Lets you copy only the main movie out of a 4K UHD disc on a new BD100/50/25 blank disc. Can also be saved a BD66 ISO or folder.
·         Lets you copy full disc to a BD100 in 1:1 lossless ratio. Though the copy process to BD50/25 discs, ISO, or folder will be compressed. Can also be saved a BD66 ISO or folder.
So, if you are looking for a true 4K UHD Blu-ray player then you can blindly go for the Xbox One X. If you not then you can go for the cheaper options like Sony UBP-X800 or Samsung UBD-K8500. All of the above mentioned 4K UHD Blu-ray players support HDR10. It’s upto you which one do you choose after taking the price in consideration. Secondly if you are looking for a UHD copy software solution then you can check out the DVDFab UHD Copy to copy your 4K UHD discs to another UHD discs or save them as ISO or a folder. It’s a software worth having because it will fulfil all your UHD copy needs.
1. Downgrade the UHD-unfriendly firmware of a 4K UHD drive to make it backup-friendly
2. Support all the mainstream 4K UHD drives from major manufacturers like Asus and LG
3. Make the downgraded 4K UHD drives compatible with 3rd party UHD backup software
4. Offer extremely easy downgrade procedures operable even by unskilled amateur users
You May Need Other Tools
DVDFab UHD Ripper
DVDFab UHD Creator
Create 4K UHD Blu-rays from any digital videos
DVDFab UHD Cinavia Removal
Remove Cinavia from the audio tracks of 4K UHD Blu-rays
