How to Convert Gif to MP4 – Best 5 ways
2019-12-25 05:47:48     Posted by John
5050
Summary: How to convert GIFs to MP4 videos? Here are the 5 best ways to convert GIF to MP4 easily and quickly.
Gifscan be tricky at times; it certainly would play on any smartphone without any tweak, but what about feature phones and other media playing devices? Mp4, on the other hand, is the most supported media format by almost every media player you would ever come across. Converting a Gif to Mp4 is not something you can easily do with your regular video converter. Most video converters of today lacks support for this media format and as such would not allow you to convert gif to mp4.
In this post, you’ll learn the top best ways to convert gif to mp4 without much stress or a lengthy learning curve.
Method one: Convert Gif to MP4 using Convertio
This is an online platform where you can easily convert gif to mp4 for free and it is fully accessible from any computer irrespective of the Operating System (Mac or Windows).
To convert gif to mp4 using this platform, simply follow the steps below.
·         Visit the website - https://convertio.co/
·         Click on the add video button to upload and add your Gif file
·         Click on convert and wait for the tool to convert your gif file
·         After the conversion, you’ll see a download button on the right side of the converted video. Click on the download button and save the MP4 format on your desired storage location.
Note: You need an active internet connection to use this gif to mp4 conversion method.
Method Two: using gif-2-mp4 online converter
Gif-to-Mp4 is an online platform where you can convert gif to mp4 in a few clicks. The platform is very easy to use and has support for a lot of media output formats.
 It is a completely free gif to mp4 converter and the conversion speed is extremely fast (although depends on your internet network speed).
Follow these steps below to convert animated gif to mp4.
·         Visit the website - http://gif-2-mp4.com
·         Click on the “Add Gif file” button and add your Gif media file
·         Wait for the Gif to be fully uploaded on the platform
·         If you wish, you can customize the resolution and output quality of the Gif media, the options are available.
·         Enter your email address where a link to download the converted file (MP4) will be sent.
·         Now proceed and click on convert.
Once the conversion is successful, you’ll receive a message to your email (provided) containing the download link of the MP4 format you wished for.
Method three: Using Any Video Converter – AVC
Any Video Converter is a versatile video converter with support for almost all the media formats you would ever come across. This piece of utility tool comes with support for Gif media format and it lets you turn gif into mp4 in few seconds.
Here are the steps to use this software in converting Gif to Mp4
First Step: Launch the software
If you do not have this software installed on your Windows PC or Mac Book, you can download it from the company’s official website
Once you’ve completed the software download, run the .exe offline file and follow the on-screen prompts to install it on your computer.
Second Step: Upload the Gif file
When you have launched the software, click on the “add or drag files” button to upload the Gif file. There are other options to add your Gif file too.
Third Step: Choose the output profile
Set your output format to MP4. To do this, click on the “select output profile” button and navigate to the general vide tab, then select MP4.
Fourth Step: Convert Gif to Mp4
Once you are done with the steps above, move on to convert your gif to mp4 by tapping on the “convert now” button. In a matter of seconds, your gif will turn to become an MP4 video file.
Method Four: Filmora Video Editor
Wondershare Filmora is a premium video editor with support for lots of media format. It lets you to convert Gif to MP4 without any lengthy learning curve.
Steps to convert animated gif to mp4 using WonderShare Filmora Video Editor
First step: Launch the software
First, you’d have to download the Filmora Video Editor to your PC, but that’s if it’s not already installed on your computer machine.
Second Step: Add your Gif file
You can drag and drop the Gif media(s) on this software interface or use the “add media” button to upload your file(s).
Third Step: Edit if necessary
Once your gif media file(s) have been successfully uploaded, you can choose to edit some aspects of the gif. This video editor comes with a complete set of video editing tools.
Fourth Step: Export as MP4
When you are done editing the Gif, locate the export menu – it is located at the Top Menu bar of the software window. Click on the export option and choose where you which to export the video.
On the Output Profile dialogue box, select MP4 and click on export. Your Gif will be exported as MP4 and saved on your choice folder/storage path.
Method Five: Using CloudConvert
Here’s another online tool and a free gif to mp4 converter that lets you turn gif to mp4 instantly. It doesn’t matter the operating system you are using, once you have access to the internet you are all set to use this tool.
Steps to convert gif to mp4 using Cloud Convert
·         Visit the website  - https://cloudconvert.com/
·         Upload your gif file by clicking the “select file(s)” button.
·         Choose your output format (MP4)
·         You can also opt in for advanced settings option if you’re a pro in handling video files
·         You can as well choose to create a Zip file folder if the converted videos are quite much
·         Click on the “Start conversion” button at the bottom of the window and your video(s) will be ready in seconds.
·         Now click on download (on the right side) and save the converted file on any storage location of your choice.
Additional Tip
If you haven’t heard about DVDFab video converter , it is a top-notched video conversion software with versatile functions. Even without support for Gif to MP4 conversion, DVDFab video converter lets you convert media files from one format to the other losslessly and at a very fast conversion speed.
It is a premium software tool mostly used by video editors and digital hobbyist for media editing and/or video conversion. The software is available for both Mac and Windows PC users.
Wrap Up:
Inmy honest opinion, these are the best ways to convert gif to Mp4 easily and without spending a penny for paid Gif to MP4 conversion services.
The top-notch video downloader software to download online videos from YouTube, Facebook, Vimeo, Twitter, Instagram, and 1000+ other popular audio & video sharing websites.
You May Need Other Tools
DVDFab DVD Ripper
DVDFab Blu-ray Ripper
DVDFab Player 6 Ultra
