Top 3 MP4 Trimmers
2019-03-18 22:42:58     Posted by Amanda
4870
Summary: Do you want to trim your MP4 videos for a certain purpose? Read the article to find the top 3 best MP4 trimmers.
Sharing videos on social media websites is a new fashion. You record a hilarious video or someone does a great videography job of your wedding day and you love to share it with your friends on internet. However, it may take a lot of time to upload a wedding video or other types. Furthermore, it is not always possible to upload the full version of a video file on some social media sites. What is the way out? It is the context where video trimming software comes into play.
The video trimmers allow you to trim the part that you think unimportant or boring before uploading the file on internet. With most videos being uploaded and run as MP4, you should learn about different MP4 trimmers that can solve your problem. There are several high-end MP4 trimmers but in this blog, we will restrict our focus to only three best of those.
Here are those to help you trim the original video files in an effective and efficient way.
DVDFab Video Converter
The fact that it tops our list of the best converters or MP4 trimmers will not surprise those who have vast knowledge in this regard. However, many are still not aware of how to do it with help of a DVDFab video converter. For them, we have described the process in a step-by-step way as follows:
Start with loading the original video. Run DVDFab 10 and reach out to Converter module. Load the original video you like to convert.
In the next step, you need to choose a profile. Go to the profile library on the main interface. You will find it on the top left corner. Choose Format>Video>General/Filter in order to select a video format. Do you want to convert the video directly to a particular device? If yes, you should click Device to select the particular device. If you prefer to convert the video file to an audio format, choose Format>Audio to select the audio format. As we are talking about MP4 trimmer, therefore you should choose MP4 format.
Customize Video File
Customization of video file is important. The step allows you to change the name of the video, subtitles and audio tracks. It is possible to add external subtitles as well as personalize your settings. There is an “Editor” icon that you can use to perform multiple functions, such as trimming, cropping, adding watermarks and subtitles, adjusting brightness, saturation and contrast of the pictures.
Step 4
Choose a Director
Click on “folder” icon placed at the bottom. Choose a directory in order to save the trimmed video file.
Step 5
Start the Conversion Process
Click on the “Start” button to convert your original video to MP4. If you are looking for ways to convert DVD to a suitable video format that you will be able to run on portable devices including video players, check a DVD Ripper for the purpose.
Now you see how much easier it is to convert any video file by using a top-rated MP4 trimmer.
Salient Features ofDVDFab Video Converter
DVDFab Video Converter is not like ordinary MP4 trimmers. In fact, it is a full-fledged video converter. Here are other salient features of this video converter.
➢     It supports a bunch of input and output file types in addition to those having MP4 formats.
➢     It’s a super fast converter. It is designed to make an optimum use of the modern technologies like Intel Quick Sync, multi-core CPU processing and hardware acceleration solutions to convert files at a blazing speed.
➢     The same feature also makes batch conversion possible.
➢     It is compatible with all the major and popular smartphones and tablets.
iMovie
It is another interesting video editing software tool to help you trim MP4 video files with ease. It is a Mac video editing software program compatible with Mac OS X. The video trimming software program works with an array of video files like MPEG, HDB, AVCHD, DV and HDV. The trimmer has a set of amazing features. With it, you can trim your video file easily. Of several video editing software programs available to work on your video file like a pro, iMovie is a powerful one due to its several advanced editing functions. Now you can get the result in no time at all. It is easing up your work and at the same time maintaining the quality. You will get the best result at the end.
Lightworks
Here is another extremely useful converter to make your work simpler and easier. An MP4 trimmer free version of Lightworks is easily available. You can use it to import, trim and weave the MP4 audio and video files together just with a few clicks on mouse. The trimmer features a set of most advanced tools for editing video files. The starters may find those little complicated at first. However, these are very convenient to use. Once you do editing a few times, all these will be lot easier to use. It is a professional software tool to edit videos and trim MP4 files. Therefore, it can easily handle large files. It can solve the purpose without any issues. In fact result will be perfect and finely tuned.
Once upon a time, video editing was not an easy job. Only the experts were trusted for the editing work. Over time, technology has made tremendous progress. As a result, it is now possible to edit the video files, even the large ones, at your home. What you need is to have a high-end editing software tool. With little practice and patience, you will be able to do editing just like a pro. You can do wonders with the help of these trimmers as it suit your purpose. You don’t need to buy software always, as you can trim MP4 online.
In this blog, we have mentioned only top 3 MP4 video trimmers. There are more. Check the options and choose what you prefer.
1. Download online videos from YouTube, Facebook, Vimeo, and over 1000 other sites
2. Allow users to choose their preferred video quality to download, up to 8K in resolution
3. Download an entire playlist or process 5 download tasks to maximize work efficiency
4. Enable turbo-speed to download 10 times faster so as to save users' invaluable time
You May Need Other Tools
DVDFab DVD Ripper
DVDFab Blu-ray Ripper
DVDFab Player 6 Ultra
