Videos not Playing on iPad? Solutions here!
2019-10-12 08:56:27     Posted by Starry
1073
Summary: This article aims to recommend you some constructive solutions when videos won’t play on iPad. Just look through the following answers to act according to actual circumstances.
It is an indisputable fact that Apple product has always been growing in popularity around the globe. For video fans, portable iPad has been the optimal choice to watch loved videos since it supports 4k Ultra HD videos as cumbersome Apple computer and smaller-screen iphone do. Nevertheless, there might be occasions when iPad won’t play videos. Why my iPad won't play videos? What has happened? At this critical moment, brainstorming will bring you the last hope of recovery. If you watch videos on iTunes, the first thing to do is check the status of iOS to make sure whether services are available or running at peak times. Otherwise, you shall find the ins and outs behind the dilemma from other perspectives. Network failure? iOS update delay? Device trouble? Incompatible video format? These questions should be taken into full consideration.
The following solutions might be helpful to hit the needle when videos won't play on iPad. The whole process of finding solutions to the problem will truly bring you a troubleshooting experience.
Part 1: Conventional Methods to handle videos not playing on iPad
Method 1: Check network status
iPad won’t play videos? To begin with, you need to check your network connection. When it comes to network fault, it is normal that you fail to watch videos online. In this case, you have to find out the reason behind network failure in order to play videos online without a hitch. After all, it will take you some dollars to pay for mobile traffic when you are anxious to see your favorite videos from the Internet.
Act as follows to troubleshoot network failure. Of course, if you cannot understand below instructions, you can turn to professionals for technical support.
a. Check WAN and LAN connections
b. Verify wireless adapter
c. Identify AP and router settings
d. Verify TCP/IP settings
e. Verify network connection with Ping
The above precedures, in a sense, will help you out when it comes to network failure.
Method 2: Download videos from PC to watch them on iPad
My iPad won’t play videos? Here, a highly recommended video downloader, DVDFab Video Downloader, will come in handy. With this practical tool, your anxiety will vanish in a flash, because you can download your loved videos from YouTube to watch them whenever and wherever possible in case of unexpected network error.
This powerful video downloader makes it possible for you to download whatever you like from YouTube at your preferred video formats. Meanwhile, you can play videos in the process of downloading with the built-in video player, or adding them to the existing playlist. Besides, this downloader allows you to download the entire playlist directly. At this moment, even if YouTube won’t play videos, you can still download the videos to play on alternative players.
Then how can you use this tool to achieve your personal goal?
First, launch DVDFab Video Downloader and click on YouTube icon from Explorer section.
Then, select and play the videos you intend to download
Last, tab the Download button appearing on the screen to download your loved videos
The above steps may help you avoid network obstacle to watching videos as expected.
Method 3: Verify iOS of iPad
Why won’t my iPad play videos? Other than regular problem, there are some deep-rooted reasons. Is there anything wrong with your iPad iOS?
If so, close your iPad and reboot it to verify whether iPad iOS runs normally or identify whether your device iOS has updated its latest version. This may avoid service interruptions or bugs that cause videos unplayable. Most of the time, update will work a lot. If iOS of your iPad is normal, then you need to rethink and analyze the failure cause from other aspects.
Method 4: Detect iPad device
Despite the fact that you have firm confidence in the quality of Apple product, there will be some time when your device breaks down due to hardware failure or the limitation of service life. Under such circumstance, please operate as below to remove the hidden risk.
Copy important files before you try the factory reset. If reset does not work at all, it is high time that you identified your iPad whether it has broken down or has been badly damaged because of human factors. If this is beyond your capacity, you have to contact Apple service center for technical support. When it comes to the end of service life, you iPad won’t play videos anymore. What you can do is purchase a new one for subsequent use.
Part 2: Update third-party player software
Gone are the days when videos were merely available in 3GP and MP4. However, with the advent of smart mobile devices, an increasing number of new formats are open to high-quality videos. Most smartphones or portable devices possess built-in media players and can be, at the same time, compatible with third-party player apps, thus enhancing users’ visual experience.
For iPad users, iTunes is the first choice to play videos. When videos will not play on iTunes, you need to check whether the iTunes player has been out of order. In the meantime, you have to update its latest version in case of any bugs. Of course, you may install and launch other app players such as  OPlayer Lite, VLC for Mobile, 8Player, MX Video Player. Whatever players you use, a quick way to resolve the problem is to update the latest version of a third-party media player. If update does not turn out to be the perfect solution, you had better try other app players.
Part 3: Convert video formats to playable ones with video converter
YouTube videos won’t playing on iPad? Unbelievable! Whereas, iPad, as a popular portable device cannot support all video formats except for mainstream ones. Therefore, when encountering such a dilemma, you need to convert videos to the ones that can play on your iPad.
In fact, there are many video converters prevailing on the market. Nevertheless, how to select a workable converter deserves your full consideration. Because the best video converters are easy to use and can address a huge array of diverse file types. Here, I recommend a feasible and powerful free video converter, DVDFab Video Converter that absolutely can help you convert videos to the formats that are playable on your iPad.
This converter can read all popular video formats from the Internet, digital camcorders, capture cards, and convert them to any mainstream video or audio formats, such as 3D MKV/MP4.H.265, 3D M2TS, 2D MP4.H.265, MKV.265, MKV Passthrough MP4 free, and audios in the form of MP3, DTS, WMA, AAC. Above all, it contains a built-in video editor that allows you to crop video display area, trim redundant video clips, merge several video clips into a single one, add subtitles and set video & audio output parameters as hoped. By the way, DVDFab products give privileges to every user for a 30-day trial that other converters do not offer. There is no exception to DVDFab Video Converter. For trial version, you have access to experiencing all features that a paid version has. However, after 30 days, the trial version will turn into free version automatically, which has restrictions on customized functions.
Enclosed here are three simple steps for your reference.
First, download and launch DVDFab Video Converter, and further load source video files.
Second, choose one profile and customize output videos.
Finally, start to convert videos.
 i  Free Download                      i  Free Download
Should you need detailed guideline on converting MKV to MP4 free of charge, please click on how to convert MKV to MP4.
Of course, there are other options for you to achieve similar objectives but with lower quality or more restrictions in some aspects.
1. Freemake Video Converter
Freemake Video Converter is famous for its quick, flexible and easy-to-use features. As a free video converter, it allows users to convert files hard drive to popular formats, or download and convert online videos from mainstream video sites such as YouTube and Vimeo.
2. Free HD Video Converter Factory
Free HD Video Converter is proud of its easy-to-use feature to perform video conversion process within a matter of seconds. Despite its editing tools that allows for profiles tailored to playable device, users have to pay extra money at the expense of customized features.
3. Any Video Converter
When it comes to numerous supported video formats, Any Video Converter can help you download videos from Facebook online, further converting these video files offline into formats that suits your portable playable device.
4. HandBrake
As a free video converter, HandBrake supports many features such as advanced filtering, frame rate adjustments, cropping and presets for quick converting results.
5. Free Video Converter
Free Video Converter boasts its clear interface and batch conversion. Besides, this converter supports a number of output formats such as MP4 and MP3, and a choice of quality settings when you need to merge clips into a single file in the process of conversion. Note that the output videos with Free Video Converter contains watermark.
Part 4: Conclusion
This article has presented you comprehensive and flexible solutions to tackle the situation where your iPad won’t play videos. With this helpful guideline, you might feel at ease when you meet the same problems. These solutions will radically make a difference.
1. Download online videos from YouTube, Facebook, Vimeo, and over 1000 other sites
2. Allow users to choose their preferred video quality to download, up to 8K in resolution
3. Download an entire playlist or process 5 download tasks to maximize work efficiency
4. Enable turbo-speed to download 10 times faster so as to save users' invaluable time
You May Need Other Tools
an online video downloading expert that gives stunning experience
DVDFab DVD Ripper
the best DVD ripping software that can quickly rip and convert a DVD to any mainstream audio & video formats
DVDFab Video Converter for Mac
the most full-featured and powerful video converter on Mac OS
