DVDFab Free Download
Download
Blu-ray Audio Extractor
2017-12-12 03:08:08
If you love a Blu-ray movie very much, you may want to extract the audio or the background music of the movie and put it on your portable audio device to playback often. So how to extract audio from Blu-ray? A Blu-ray audio extractor is the thing you need.DVDFab Blu-ray Ripper is the best Blu-ray audio extractor that can extract the entire audio track or audio clip from Blu-ray movie and convert the audio to various audio formats like AAC, MP3, M4A and more quickly and easily. Now let’s see how this Blu-ray audio extractor works.
Step 1: Load the video you want to convert
Run DVDFab 10, go to Ripper module and load the Blu-ray source as the instruction on the main interface.
To extract an entire audio track, read Part 1; to extract audio clip, read Part 2
Part 1
Step 2: Choose an audio format
Go to the profile library on the top left of the main interface, click Format > Audio to choose an audio format you want.
Step 3: Customize your audio
After the source is loaded, the main movie title will be selected by default, but you can also choose other titles here. Then you can change the title name, choose the audio track you like and click the “Advanced Settings” panel to customize your settings.
Step 4: Save the audio and start the conversion process
Move to the bottom of the main interface and click the “folder” icon to select an output directory to save the audio. And then click the “Start” button to start the process of converting Blu-ray to audio.
Part 2:
Step 2: Choose a video format and trim the video
Go to the profile library on the top left of the main interface, click Format > Video > General to select a video format causally. Go back to the main interface, you will find the main movie is selected by default. But you still can choose other titles. Click the “Editor” icon at the right part you can go into the panel where you can trim the video. Click the “Trim” tab, and then you can drag the start tab and end tab below the timeline to trim out the video (audio) part you don’t want. Then click “OK” button to go back to the main interface.
Step 3: Choose an audio format
Go to the profile library again and click Format > Audio to choose an audio format you want.
Step 4: Customize your video
Now you can change the title (audio) name, choose the audio track you want and click the “Advanced Settings” icon to customize your settings.
Step 5: Save the audio and start the conversion process
Move to the bottom of the main interface and click the “folder” icon to select an output directory to save the audio. And then click the “Start” button to start the process of extracting audio clip from Blu-ray.
Follow the above steps, you can extract audio from Blu-ray easily. Blu-ray Ripper provides 30-day free trial, so please feel free to download it and have a try.
Also want to rip DVD to various video/audio formats? Click DVD Decoder to learn more.
  • Discount
    Copy & Paste Coupon Code:
    MAMP-FAB-OFF
    When Checking out.
    Mar 25, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
