DVDFab Free Download
Download
How Do I Copy a DVD?
2019-05-10 07:42:25
Do you want to copy or burn your precious DVDs for backup? Then DVDFab DVD Copy would be one of the best DVD copy tools for you. With DVDFab DVD Copy, you can either customize the output DVD or make a 1:1 copy. It also allows you to rip the DVD to ISO file or DVD folder to store the DVD on your hard drive. Moreover, its copy speed is prominent among multitudes of DVD burners. Now let me show you how to copy DVD with DVDFab DVD Copy.
Step 1: Choose a copy mode
Run DVDFab 11, go to Copy module and click the "Copy Mode" tab on the top left corner of the main interface to choose a copy mode. You have 6 modes (see Note at the end) to choose. Here I take Main Movie mode as an example.
 how do i copy a dvd
Step 2: Load the source
Insert the DVD disc and DVDFab will load it automatically. Or you can click the “Add” button to load the source manually. If the source is an ISO file or folder, you can directly drag it to the main interface to load it.
how do i copy a dvd
Step 3: Customize your DVD
After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and make advanced settings according to your needs. On "Advanced Settings" panel, you can decide the output as DVD 5 or DVD 9.
how do i copy a dvd
how do i copy a dvd
Navigate to the bottom of the main interface to select a directory to save the output DVD: to select your optical drive as the directory from the drop-down list box is to save the output to a blank disc; to select a directory by clicking the "Folder" icon is to save the output as a DVD folder; to select a directory by clicking the "Image" icon is to save the output as an ISO image file.
how do i copy a dvd
Note:
6 modes:
Full Disc: copy all the contents of the disc/ISO/folder source.
If you choose to save the output to a blank disc, you will be prompted to insert a compatible media to your optical drive during the copy process. Just insert a blank disc to continue the clone process. DVDFab is not only a DVD copy tool, but also provides all-inclusive solutions for all your DVD/Blu-ray/video issues. For instance, you can also use DVDFab to convert DVD to MKV.
  • Discount
    Copy & Paste Coupon Code:
    JUSP-FAB-OFF
    When Checking out.
    Jun 24, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
