DVDFab Free Download
Download
How to Clone DVD with DVDFab DVD Copy?
2019-03-07 09:35:05
Sometimes you may want to clone several pieces of your DVDs for backup or to playback in different places. Then what you need is a DVD clone tool. DVDFab DVD Copy is a great DVD clone tool which can help you clone your DVD with only several steps. Moreover, supported by advanced technologies, it can clone DVD at a pretty fast speed. Now, let’s have a look at the clone process.
Step 1: Choose a copy mode
Run DVDFab 11, go to Copy module and click the "Copy Mode" tab on the top left corner of the main interface to choose Clone/Burn mode.
how to clone dvd
Step 2: Load the source
Insert your DVD into your optical drive and DVDFab will load it automatically, or you can click the “Add” button to load the source manually.
how to clone dvd
Step 3: Select an output directory
Navigate to the bottom of the main interface to select a directory to save the output DVD: to select your optical drive as the directory from the drop-down list box is to save the output to a blank disc; to select a directory by clicking the "Image" icon is to save the output as an ISO image file.
how to clone dvd
Step 4: Start the clone process
Click the "Start" button to start the clone process.
Note:
If you choose to save the output to a blank disc, you will be promoted to insert a compatible media to your optical drive during the copy process. Just insert a blank disc to continue the clone process. Please refer to DVDFab DVD Copy for more detailed information about DVD clone.
  • Discount
    Copy & Paste Coupon Code:
    MAMP-FAB-OFF
    When Checking out.
    Mar 25, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
