DVDFab Free Download
Download
How to Rip and Convert Blu-ray to MKV with Blu-ray to MKV Converter?
2019-01-11 04:20:13
Whether you download videos off the Internet or get them from other people, it’s very likely that you may come across MKV files. MKV, a comprehensive multimedia container file format, is compatible with nearly all media players. Therefore, MKV is one of best options when you want to rip or convert a Blu-ray to a format playable on your portable devices. DVDFab Blu-ray Ripper is a professional Blu-ray to MKV Converter, with which you can easily convert Blu-ray to MKV. Now let’s have a look at the conversion process.
Step 1: Load a source
Run DVDFab 11, choose the “Ripper” module and load a Blu-ray disc/folder/ISO file you want to rip as instructed in the main interface.
rip a blu-ray
Step 2: Choose a format
Navigate to the profile library on the top left corner of the main interface and choose Format > Video > MKV.
blu-ray ripper
Step 3: Customize your file
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, define the names of the chosen titles, and make advanced settings if needed. You are even able to edit the Blu-ray video with the built-in editor.
mkv converter
rip to mkv
blu-ray ripper
Step 4: Select a dictionary
Click the "folder" button to select a directory to save the output video.
mkv converter
Step 5: Start the conversion process
Click the "Start" button to start the ripping process.
If you want to know more about this program, please refer to DVDFab Blu-ray Ripper.
  • Discount
    Copy & Paste Coupon Code:
    JUTK-FAB-OFF
    When Checking out.
    Jul 1, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
