NEW
Get 30-Day Free Trial
Windows 10/8.1/8/7
macOS 10.10 - 10.14
2017-08-03 22:32:23
M4A is an audio format, which is widely used in Apple devices. If you want to extract the audio of a movie out of the DVD video and play the audio on your iPod, you need to convert the DVD to M4A. DVDFab DVD Ripper is a powerful tool that can rip DVD to M4A quickly. Now please follow me to have a look at how to convert DVD to M4A with DVDFab DVD Ripper.
How to Rip and Convert DVD to M4A with DVD to M4A Ripper:Step 1> Run DVDFab 10 and choose the Ripper module.
How to Rip and Convert DVD to M4A with DVD to M4A Ripper:Step 2> Insert the DVD into your optical drive, and DVDFab will load the content on the DVD automatically. You can also load the source manually by clicking the "+" button. But if the source is a file/folder, you can drag the file/folder directly to the main interface to load it.
How to Rip and Convert DVD to M4A with DVD to M4A Ripper: Step 3> Navigate to the profile library on the top left corner of the main interface and choose a video format randomly. Click the Editor icon to go into the editing panel and choose the Trim tab. Here you can drag the start tab and end tab to decide the length of the video, which in fact is the length of the output audio. After you finish the work, click "OK" button.
How to Rip and Convert DVD to M4A with DVD to M4A Ripper:Step 4> Go to the profile library again and choose Format> Audio> M4A.
Then you can choose the audio you want and change the names of the title at your option. Click the "Advanced Settings" icon, you can set the parameters of the audio, which include the codec, bit rate, sample rate and so on.
How to Rip and Convert DVD to M4A with DVD to M4A Ripper:Step 5> Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the ripping process.
If you want to get more information about DVDFab DVD Ripper, please go to https://www.dvdfab.cn/dvd-ripper.htm.
① Rip and convert DVDs to watch on PCs, smartphones, tablets, etc. ② Extract the audio tracks from DVDs and output as pure audio files ③ Support all the popular audio & video formats like MP3, MP4, MKV, etc. ④ Support to edit the videos like cropping, trimming, and more ⑤ Support GPU hardware acceleration to convert much faster
Hot Sellers
