DVDFab Free Download
Download
How to Rip and Convert Blu-ray to M2TS with Blu-ray to M2TS Ripper?
2019-03-11 07:37:33
M2TS is the container format commonly used for high definition video on Blu-ray Disc and AVCHD. M2TS can provide you with better viewing experience than other common HD formats. If you want to convert your Blu-ray to video files in high definition playable on computer and other playback devices, you can convert Blu-ray to M2TS. DVDFab Blu-ray Ripper is an excellent Blu-ray to M2TS ripper which can help you do the conversion job efficiently and effortlessly. Now let’s have a look how to rip and convert Blu-ray to M2TS with Blu-ray to M2TS ripper.
Step 1: Load a Blu-ray source
Run DVDFab 11, go to Ripper module and load the Blu-ray source according to the instruction on the main interface.
how to rip and convert blu ray to m2ts
Step 2: Choose the M2TS profile
Navigate to the profile library on the top left corner of the main interface and choose Format > Video > M2TS.
Step 3: Customize your M2TS video
 After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, define the names of the chosen titles, and make advanced settings according to your needs. You are even able to edit the Blu-ray video with the built-in editor.
Step 4: Select an output directory
Navigate to the bottom of the main interface and click the “Folder” icon to select an output directory for your M2TS video.
Click the “Start” button to start the process of ripping and converting Blu-ray to M2TS.
Please refer to DVDFab Blu-ray Ripper for more detailed information.
  • Discount
    Copy & Paste Coupon Code:
    MAMP-FAB-OFF
    When Checking out.
    Mar 25, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
