DVDFab Free Download
Download
How to Rip DVD for Watching on Samsung Gear VR?
2017-08-04 02:32:23
Samsung Gear VR is a mobile virtual reality device, which acts as the headset's display and processor. Whenever you want to enter virtual reality, just take your Galaxy smartphone, slide it in the Gear VR, then put on your Gear VR, you are in there in the moment.
One advantage of Samsung Gear VR is that Samsung and Oculus has made it easy to import and watch your own DVD movies in virtual cinema mode. So if you want to watch your favorite DVD movies with this wonderful device with a super AMOLED display, wide field of vide, precise head-tracking and low latency, all you need is an efficient DVD ripper. DVDFab DVD Ripper, a well-received and powerful DVD ripper can rip DVD to Samsung Gear VR supported videos painlessly.
Following, let's see how to rip DVD for watching on Samsung Gear VR with DVDFab DVD Ripper.
Step 1: Download the latest DVDFab 9 or update your DVDFab to the latest version
Step 2: Run DVDFab DVD Ripper, and load the source DVD
Get DVDFab 9 started after installation or update, and opt for DVD Ripper from the option bar. Following, insert the DVD disc you want to rip into the optical drive, or navigate it according to the hints displayed on the main UI.
Step 3: Choose Samsung Gear VR, and personalize the output video
After source loading, move to the left pane and click the profile switcher. Choose Samsung Gear VR following: Device -> 3D Device. Then, select the titles, audio & subtitle stream to be kept in the result as well as the output size.
Set the audio and video parameters regarding the output DVD from the Advanced Settings part in case you need.
You can also make deep customizes like adjusting the video effect, trimming the video based on second, cropping or rotating the video, adding image or text watermarks, adding external subtitles, etc.
After that, don't forget to select the output directory with enough disk space for storing the result temporarily.
Step 4: Start to rip DVD to Samsung Gear VR
Now that you've made settings you need, just click the Start button, DVDFab will immediately begin ripping DVD to Samsung Gear VR while present you the detailed progress information. You can also cancel the task anytime you want.
That's all! Very simply, right? Now, just transfer the output video from the output directory to your smartphone, and slide it to your Samsung Gear VR, you can enjoy the big time then.
Have a nice time!
  • Discount
    Copy & Paste Coupon Code:
    JUSP-FAB-OFF
    When Checking out.
    Jun 24, 2019
    The Universal Master Key
    Price: $69 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $84.9 Buy Now
